Okay, first the disclaimer: Sorry about the fuzzy pictures, didn't realize until after I got everything back together that there was a problem with my camera
lens. Also I realize the wiring diagram is a bit crude so if you need any clarification feel free to ask me.
So here is what I started with: 98 outback seats, both plugs on the seat side and no plug for the switches. Finding connectors that will fit on the thin
connector of the plugs is possible, but a pain so I would recommend getting the switch plug as well if you can. These went in to a 90 Legacy L model, though
wiring is the same for any car that doesn't already have a seat heater wiring harness.
What you need:
*~10 ft of wire from battery
*Inline fuse for
*wire for grounds (anywhere from 2 feet and up depending on where you choose to ground it)
*wire for seat to switch harnesses (recommend 20 gauge, larger is unnecessary and just makes the bundle big)
*Relay (minimum of 20 amp, dual 87 terminals is easiest, standard trailer wiring relays work great)
*female spade connectors if you don't have harnesses for switch and seat
*Post connectors for Battery connection and grounds
*Splice connectors if needed
*Zip ties, lots of zip ties
What I used:
*10 gauge wire from battery (little excessive, but I plan on installing future rear power outlets so I wanted extra future capacity)
*14 gauge wire for grounds (I like black grounding wire, and thats what I had laying around)
*16 and 18 guage harness wires (used what I had)
*40 amp relay (just happened to be the one they had in stock with two 87 terminals)
Step 1
Run the power wire from the battery with an inline fuse (fuse should be close to the battery)
On the first gen legacy's there is a little rubber cover on the passenger side. Poking a little hole in the rubber lets you slide the wire through just
behind the glovebox and you can route it under the carpet and up the center console.
Step 2
Connect/install relay. I mounted mine right next to the handbrake and grounded the ground terminal to the mounting screw.
The red wire comes from the battery, green is the relay activation source. I used the power wire for the cigarette lighter for this, but any source that
powers on with the key will work. The idea here is to shut off power to the seats whenever the car is off to prevent battery drain. The brown wire in the
picture is the ground.
Step 3
Build/connect seat harnesses. I forgot to take a picture of the harness before I installed it but I'm sure you have an idea of what it should look like.
Luckily this part is only three wires so shouldn't be too tough to route, I went under the carpet via a hole I carefully cut with a razor. (having the seats
out would have made this WAY easier)
Step 4
Connect the switches. This is where the wiring gets a bit messy, make sure you have everything clearly labeled to avoid hooking things up wrong, or backwords
in my case. One thing to remember is that the seats do not ground via the switches directly so the ground wire in that harness does not need to be bundled
with the other two wires. If you plan ahead this means you can connect those grounds first, out of the way, and have two less wires running around in your
switch area. My finished harness looks like so:
with a ready to connect bundle as such:
Step 5
Close switch panel and admire your handiwork.
Of course, if you have a little more motivation you can always make your switch installation a little prettier, I got a little lazy so they stick out a bit.
Step 6
Flip the switch to high and sit back and wait for that nice warm butt.
Step 7
Troubleshoot why your butt isn't warm. If you get to this point start with the easiest first. Check to see if you remembered to put a fuse in the fuse holder
(because you were smart and DIDN't put one in the first place I hope). Next check your grounding wires. Then check the Switches for proper operation (FSM
link below). Check the harness and seats for proper connections (FSM again). Check the wiring diagrams again just to double check that you read it right. Log
on to the bbs.
Wiring diagram and Links
FSM Service Procedure
http://www.main.experiencetherave.com/s ... cedure.pdf
Factory Wiring Diagrams
http://www.main.experiencetherave.com/s ... iagram.pdf
Final notes
First, keep things neat, loose wires are lazy and are the leading cause of gremlins. Second, use shrinktube and solder whenever possible. Twist connections and electrical tape are not the best and only save time the first time you install it. If anyone has any questions feel free to ask.
