injector question
Posted: Tue Sep 08, 2009 1:08 am
by 92legacyss
If i put sti fuel rails on my ss could i use the top feed style injectors??
Posted: Tue Sep 08, 2009 4:44 pm
by macipusy
I am pretty sure the top feeds take a different intake manifold to work.
You can get n/a 2.2L fuel rails and run STi side feeds.
Posted: Tue Sep 08, 2009 5:29 pm
by 92legacyss
ok thanks
Posted: Tue Sep 08, 2009 5:36 pm
by asc_up
For what it's worth, I'm running JDM 440cc side feed injectors (gray tops) in the stock Legacy Turbo rails.
Posted: Wed Sep 09, 2009 1:19 am
by 92legacyss
nice do you know where i can get some or where you got yours? Also do the electrical connections match up or do they need to be custom
Posted: Wed Sep 09, 2009 1:21 am
by 92legacyss
On another note, The TD04, TMIC, WRX coolant reservoir and Atmos BOV are going on, friday i will post pics under the turbo section of the forum after i am done
Posted: Wed Sep 09, 2009 7:14 am
by AWD_addict
Connectors are the same style between EJ22T pink tops and EJ20G gray tops. They are just rotated 180 degrees.
Posted: Wed Sep 09, 2009 2:27 pm
by 92legacyss
Thanks that helps alot
Posted: Wed Sep 09, 2009 3:08 pm
by macipusy
Think about how much you are going to mod your car.
If you get the 440's and decide the td04 is too small for you, you'll most likely have to upgrade injectors again to match a bigger turbo.
If you go with the STi 550's in N/A rails, you can down tune them and have room for upgrading to a vf39 later if you wish.
Posted: Wed Sep 09, 2009 5:45 pm
by 92legacyss
Alright thanks
