The $9 ALK
The $9 ALK
So yesterday I picked up a set of 99 GT rear front control arm bushings for $9 from the local pull and save.
I found out the 98 and 99 GT's and Outbacks use the bushing bracket which offsets the bushing and lowers the control arm mounting hole by about an inch. This is the same concept as an anti-lift kit.
I installed these yesterday and the car has a lot more control in turns, especially long sweeping ones. Feels more balanced overall. On acceleration, the nose doesn't lift that much anymore either. Overall a great cheap suspension mod.
I am going to try to find another set and press in the poly bushings I have. That should stiffen things up a bit more.
maciek puszynski
16 WRX | 6mt | fa20
2.36L Turbo - RSTi Build
16 WRX | 6mt | fa20
Forester's do too:
http://bbs.legacycentral.org/viewtopic. ... hlight=alk
Edit: which poly bushings do you have? Hopefully not the prothane ones...
SUBARUEHS Racing
Yes, they are the prothane.....why?
maciek puszynski
16 WRX | 6mt | fa20
16 WRX | 6mt | fa20
I've yet to see a successful install. The inner sleeve is wrong:macipusy wrote:Yes, they are the prothane.....why?
SUBARUEHS Racing
You used the prothane bushings? If they work that would be great.
The stock ones that came off the 99GT seem to be leaking fluid already....just 1 week on my car and they were totally fine when I installed them.
maciek puszynski
16 WRX | 6mt | fa20
16 WRX | 6mt | fa20
Re: The $9 ALK
The Whiteline ALK that you are comparing to is designed to reduce the amount of anti-lift that is built in to the stock suspension geometry. The net effect is intended to increase traction under acceleration by allowing more lift.macipusy wrote:...
They published a white paper explaining the whole thing:
http://www.whiteline.com.au/articles/Ef ... 0ALK_b.pdf
Either way, this part substitution should net much of the same results as using the Whiteline kit. Especially with a urethane or Group N bushing. That's a cheap mod, and that's cool.
-steve-
03 Legacy L Wagon
91 Legacy Sport Sedan - SOLD
03 Legacy L Wagon
Re: The $9 ALK
I guess I hadn't mentioned this, but no, GTs do not use a different bushings. Here's a 98GT bushing next to a whiteline ALK:macipusy wrote:So yesterday I picked up a set of 99 GT rear front control arm bushings for $9 from the local pull and save.
The 99 GT ones I got were more like the Whiteline on the left in that picture....the stock 91 bushing was more like the one on the right
maciek puszynski
16 WRX | 6mt | fa20
16 WRX | 6mt | fa20
I swear it was a green 99GT I pulled these off of....if the taller bushings never came on the GT's then the owner must have swapped them before wrecking it.
maciek puszynski
16 WRX | 6mt | fa20
16 WRX | 6mt | fa20
96-99 Outback and Forester for sure
maciek puszynski
16 WRX | 6mt | fa20
16 WRX | 6mt | fa20
