Help needed with ABS sensor fitment
Posted: Mon Oct 05, 2009 9:41 pm
I've got a '98 bk (Legacy L wagon w/2.2L) w/ABS. The right front bearing and hub were shot on it. I checked parts catalogs and supposedly the first and second generation Legacies steering knuckles are interchangeable. The only steering knuckle in good condition that I could find was at a local pick-and-pull from a '93 Legacy LS which had rather new brakes, rotors, ball joints, axles, etc. (the car was scrapped because it was T-boned).
Well, all the suspension, steering, and brake parts fit on the "new" knuckle EXCEPT the ABS speed sensor does not fit into the steering knuckle. The '89 sensor's diameter is larger than the hole it's supposed to fit into.
I've got basically two questions:
1--Can I drive without installing that right front speed sensor and if so, where do I secure it (until I obtain the correct knuckle)? Will the brakes lock up on me or something? The sensor is magnetic so if I tie it off somewhere can it be touching metal?
2--If I cannot or should not drive the car with the speed sensor uninstalled, can I have the steering knuckle hole for the speed sensor enlarged (like drilling it out to make the speed sensor fit)? Is this a machine shop job or could I do it myself? If I can do it myself, how do you recommend I go about doing it?
Thanks is advance for all of your input!
