urgent removing turbo
Posted: Thu Oct 08, 2009 11:04 pm
by ericem
hey pulling the turbo out and got all the bolts off except the one for the uppipe since its under the down pipe. Does the whole dp need to be removed or is there a way to wiggle the dp back so i can undo the bottom uppipe bolts ??
Posted: Thu Oct 08, 2009 11:47 pm
by adema2626
Whole dp needs to be removed sorry to say.
Posted: Fri Oct 09, 2009 1:17 am
by ericem
lol figured it out just undid the two bolts holding the DP solidly in place then I was able to pull the DP back and slid out the turbo.
Now here is another question why do people no replace the oil drain hose? It seems easy enough with long needle nose pliers.
Posted: Fri Oct 09, 2009 2:14 am
by asc_up
Hahaha juuuuust wait. It might seem easy enough now, but it has to be the PERFECT length. Too long and it'll kink, too short and it won't reach. Therefore, getting the correct diameter and length hose is HARD because you barely have any room to work in there.
Posted: Fri Oct 09, 2009 3:00 am
by ericem
wait i can't get it at the dealer ship?? Won't it continue leaking if I leave it?
Posted: Fri Oct 09, 2009 3:26 am
by BSOD2600
Is it leaking at the oil return tube, because its cracked, etc? I'm sure you can buy most thing at the dealership... just going to cost you a bit for that custom cut piece of tubing
Yes, getting the clamps around that tube are a bitch, even with the DP out of the way....
Posted: Fri Oct 09, 2009 3:47 am
by ericem
i don't know if its cracked but its definitely insanely sludged up moist. Ill get a price and tell you guys how much it was.
Posted: Fri Oct 09, 2009 4:51 am
by AWD_addict
Or you can get hose at NAPA and cut it to the length you want.
Posted: Fri Oct 09, 2009 6:19 pm
by asc_up
AWD_addict wrote:Or you can get hose at NAPA and cut it to the length you want.
+1. Just make sure you get hose that's meant to have oil run through it, NOT heater hose.
Posted: Fri Oct 09, 2009 7:38 pm
by 93forestpearl
^ This. You need hydraulic hose, like weather head or something oil rated. Heater hose ballons up quite nicely. Don't ask how I learned that one.
Posted: Fri Oct 09, 2009 7:49 pm
by ericem
When it stops raining I will go outside and clean the area. I think all I need is better clamps the butterfly clamps don't do anything, the hose is still somewhat soft btw.
Posted: Sat Oct 10, 2009 12:26 am
by biggreen96
93forestpearl wrote:^ This. You need hydraulic hose, like weather head or something oil rated. Heater hose ballons up quite nicely. Don't ask how I learned that one.
Truth. I replaced many of the crank to head breathers and they are sweating oil. Ugh.
Posted: Sun Oct 11, 2009 1:48 am
by SubiePrice88
I pulled my turbo just to fix the oil outlet tube, Its a pain in the ass but worth it.
I got mine at a place in Spokane called "House Of Hose" and it didnt cost more than $3.00.
The dealership was to spendy for me.
As long as you cut the hose to the same length and use better clamps your good. I also used the red high heat silicone on both ends just for security. Its been 4k miles and I havent had a problem.
Posted: Sun Oct 11, 2009 4:54 am
by ericem
Hose appeared to be fine so left it just made the butterfly clamps have wayy more tension by bending them in. Turbo is in. Did my 90 for the inlet on the td04 now need to work on the IC.
