injectors: ohm reading related to fuel flow?
Posted: Fri Oct 09, 2009 9:22 am
by 93Leg-c
Would the ohm readings of a set of injectors give indication which injector flows more or less fuel?
For example, if one injector read 11.8 ohms and another had a reading of 11.5 ohms, would one injector flow more fuel than the other?
I wanted to know because if the ohm reading is an indicator of fuel flow, the highest flowing injector could be installed in cylinder 4, which runs hotter than the others.
I realize that fuel-flow testing is the best way of knowing exactly what each of the injectors flow but I thought this might be a "poor man's" way of getting the engine a bit more balanced.
Posted: Fri Oct 09, 2009 2:52 pm
by roundeye
in short, no. just differences in the coil impedance. injectors are on/ off, flow is determined by the internal port sizes.
Posted: Fri Oct 09, 2009 3:57 pm
by magicmike
Injectors are just like a relay. the coil side is just activating a valve that is on the fuel side. Pretty basic and not related.
Posted: Sat Oct 10, 2009 4:45 am
by AWD_addict
I agree, there's only one useful flow characteristic you can measure like that. If an injector reads way over 12 ohms, it will not flow at all because the coil is bad. :P
Posted: Sat Oct 17, 2009 3:44 am
by 93Leg-c
I thought I had posted a "thank you" for helping me out but I guess I didn't. So, here's a belated THANK YOU! for the posts, guys! I appreciate your help!
Posted: Sat Oct 17, 2009 3:47 am
by 93Leg-c
AWD_addict wrote:I agree, there's only one useful flow characteristic you can measure like that. If an injector reads way over 12 ohms, it will not flow at all because the coil is bad. :P
So, if injector A reads 11.9 ohms and injector B reads 11.6 ohms, is injector B technically a "better" injector or perhaps one that will have the coil last longer?
Posted: Sat Oct 17, 2009 5:50 am
by BSOD2600
93Leg-c wrote:So, if injector A reads 11.9 ohms and injector B reads 11.6 ohms, is injector B technically a "better" injector or perhaps one that will have the coil last longer?
The FSM lists the specified resistance is 11-12 ohms, so they're both within specifications.
