WTB..Can anybody locate ej22t headgaskets
Posted: Tue Oct 20, 2009 7:06 pm
by jdmleggy97
So does anybody have the ability to locate/ have any multi layer steel headgaskets for a 22turbo. I can only locate 1 in my area so....
Posted: Tue Oct 20, 2009 9:19 pm
by Splinter
I couldn't find any 6 months ago so I ended up getting some cometics.
Felpro still makes MLS gaskets for the 22T, but I don't know if they're the same quality as OEM, I've never really looked into it.
Posted: Tue Oct 20, 2009 9:51 pm
by jdmleggy97
I checked felpro themselves. They only have 1 available... Basicly I just need stronger gaskets for my 1.8t. I was fiddiling around and boost got waayyy to high..then smokie smokie!
Posted: Wed Oct 21, 2009 4:58 am
by mike-tracy
I got my Felpro's at Autozone, they were special order, which took 3 days. My friend who worked at a Subaru dealership said they never saw anyone with these aftermarket gaskets come in blown. Course someone could easily fail to follow the torquing procedures...
I think they were under $50 when dealership is almost 2x that, we're talking ej22t ones here.
edit: link
Autozone - $22.99 each. MLS gaskets.
Posted: Wed Oct 21, 2009 5:52 am
by race_to_live
here is a good place. lots of parts and such...
http://www.importperformanceparts.net/
on the left side select subaru and then there is a bunch of stuff, you can find them there
Posted: Wed Oct 21, 2009 5:59 am
by 93forestpearl
The OEM 22T gaskets are plenty strong up to whatever you plan on making power wise.
Derek blew his when he overboosted to over 35 psi from GT3076R. Rather, the Zeitronix maxed out at 35 psi, so we don't really know what it actually hit in terms of pressure. 28 psi from my turbo and they worked just fine.
Posted: Fri Oct 23, 2009 7:23 pm
by Splinter
93forestpearl wrote:The OEM 22T gaskets are plenty strong up to whatever you plan on making power wise.
The OLD gaskets were, but sometime between 12-24 months ago subaru superseeded the old MLS gaskets to a standard graphite gasket.
Posted: Tue Oct 27, 2009 5:57 pm
by MikeyMeyagi
i went right to subaru and had them next day....
Posted: Tue Oct 27, 2009 6:17 pm
by 93forestpearl
Those were graphite gaskets. I also used the graphite gaskets in mine, since that's what came in both of my engine seal kits. All the 22T's I've taken apart had graphite gaskets in them.
I'm not sure what the 1.8 came with though.
