Exhaust pops
Posted: Wed Oct 21, 2009 12:11 am
by Apex3
I don't know that this is actually exhaust related, that's why I'm in the engine section.
My exhaust pops sometimes, it'll do it if I'm coasting and just push down very lightly on the gas to where the accelerator is just engaged, it also does it sometimes when I get on it in first a little bit and then shift to second.
It's the same kind of pop you hear from the catless cars like racecar/rally car style. I assume I'm running rich for some reason, but I'm not really sure. The engine is stock, aside from the snorkus delete. I also don't have a muffler, the problem became apparent when I took it off, right now it's just a pipe in place of a muffler. It may have been doing it before but the stock exhaust is too quiet for me to know. I don't have a BOV or anything, and it's stock boost, stock intake
Also maybe related is a small vacuum leak, I'd fix it if I knew where it was, I just think that's what it is because it idles like it.
Any ideas? Or is it normal when you don't have a muffler? haha
Posted: Wed Oct 21, 2009 12:39 am
by adema2626
I would say this is normal. Mine did this when I had a 3in exhaust from the turbo back. These cars run rich in general. It's just the extra fuel igniting in your exhaust.
It will destroy your cat, if you have one. But other then that it wont do anything.
It's really fun when your driving by some one and you do it. Scares them a little haha.
Posted: Wed Oct 21, 2009 1:10 am
by Apex3
Yea, I love it, haha, I just don't wanna break anything, not too concerned about the cat, if it breaks I get to take it out and make ~$200, win win, just gotta be sure to register it at school again where there's no emissions tests.
Posted: Fri Oct 23, 2009 4:11 am
by DLC
When my 00 GT was popping a lot, it was followed by a faulty knock sensor. I'm thinking that the timing was a bit too far advanced, and with it running lean, it was chatty.
After the new sensor it quieted down a lot. Might be worth looking in to.
Posted: Sun Oct 25, 2009 2:18 am
by jefferson
There is a good chance that you have a small exhaust leak that is letting in some air on the overrun. That will cause popping too.
Jeff
Posted: Tue Oct 27, 2009 4:03 am
by LookAsubie
Mine does the same thing at the exact same times you mentioned..
but my car is catless 3" from the turbo back.
Its pretty normal and nothing to worry about at all.
and i think it sounds pretty sick :-)
Posted: Mon Nov 02, 2009 8:58 pm
by Legacy Konig
I don't know man, any noise other then engine noise would seem bad to me.
I don't think any popping is good.
...Unless you're talking about that popcorn popping noise you can make cars with headers or without mufflers make.
That.... "Baa-bi-dah-baa-bi-dah-bah-bi-dah" noise you get gearing down for the stop sign?
..or something else :shock:
Posted: Tue Nov 03, 2009 4:33 am
by Apex3
Well since I don't have a muffler I have to assume that's it :D it's the same kind of popping a race car makes when downshifting but obviously not so loud and obvious.
I think I'm just not gonna worry about it. When I can afford it I'll start replacing sensors
Posted: Tue Nov 03, 2009 6:00 am
by douglas vincent
Most likely you have a leak somewhere in the exhaust system that can PULL in air, ie oxygen, that then can cause the unburnt fuel to ignite.
God knows, thats my problem!
