moog cam bolt kit adjustment range from -1 to +1 Deg
Posted: Mon Nov 02, 2009 10:39 pm
by yazmo
hi guy i just got my cam bolt kit
these support adjustment range from -1 to +1 Deg
i got only thre front bolt and just one bolt lol yeah you heard it
1 bolt anyway before ordering the rest of the part i would like to know what you rhink about these, right now i feel a lot of body roll while cornering and i would lke to know if these bolt are right for 14$ each its something ii really like to have opinion on.
these are from MOOG
any tought?
Posted: Tue Nov 03, 2009 4:44 am
Do you have a link you could post to the part in question?
Posted: Thu Nov 05, 2009 1:39 am
by yazmo
i wish i could josh but this is from rockauto.com
and there is no direct link since its a online catalogue
just browse for subaru 1994 on suspension and you will see it very easy
Posted: Thu Nov 05, 2009 7:36 pm
These are just camber bolts. All they do is help you get some more camber. They are not going to help body roll. You shouldn't need them in the front, and you may not even need them in the rear. The rear suspension tends to already have a decent amount of camber, around -1 deg or more.
I would recommend upgrading your rear anti-sway bar if you're experiencing a lot of body roll.
Posted: Thu Nov 05, 2009 10:45 pm
by yazmo
what size 22mm? 20mm?
Posted: Fri Nov 06, 2009 7:05 pm
I probably wouldn't recommend anything bigger than a 20mm for daily driver. I've got one of the WL adjustable bars, and have it set at 20mm.
Posted: Tue Nov 10, 2009 5:59 am
by jamal
I, on the other hand, recommend big swaybars and lots of camber.
Currently on 22mm front and rear adjustable whiteline bars, and if they came bigger I would prefer 24mm bars.
I also have -2.5 degrees of camber in the front and -1.1 in the rear. The alignment is spot on for my usage and setup, since my front tire wear is dead even across the tread.
Posted: Tue Nov 10, 2009 8:41 pm
Yup....like Jamal indicated, there's different options, depending on how you drive and what you like...
