Front crank seal repeated failure. wtf.
Posted: Tue Nov 03, 2009 1:16 am
by MikeyMeyagi
so this is the 3rd time this has happened, the front crank seal on my car keeps pushing out, and wearing on the timing gear till it starts leaking. ive replaced it twice, and this last seal i glued in with hondabond sealer. im leaking oil again and i can imagine the damn seal came out again....
my pcv system is basically a breather system open to atmosphere, and both valve covers are vented to atmosphere too. i was thinking about making a positive crankcase evac system off the exhaust, to try to fix this problem.
any thoughts?
Posted: Tue Nov 03, 2009 1:26 am
by 206er
what brand of seal were you using? I have heard to only use genuine subaru seals because aftermarket do not fit just right. however if you glued it in and it popped out something definitely is not right. could something be wrong with the oil pump?
Posted: Tue Nov 03, 2009 2:11 am
by MikeyMeyagi
the seal i get at napa has the same markings of the oem seal.
idk how the oil pump could be out of round or too big for the seal but its possible i guess.
Posted: Tue Nov 03, 2009 3:08 am
by douglas vincent
How many miles on the block?
I am betting your #3 bearing is worn to shit and you are getting crank walk.
Remove all belts and firmly grab your crank and yank it back and forth. Not your penis. If it moves significantly, then the thrust bearing #3 is WORN OUT.
Posted: Tue Nov 03, 2009 3:15 am
by kimokalihi
douglas vincent wrote:How many miles on the block?
LOL!!!
I had crank walk pretty bad on an EJ22T. It moved about 1/8+ inch in and out by hand. Which is like 25X more than the maximum allowance in the FSM.
Posted: Tue Nov 03, 2009 3:43 am
by Mattheww044
omg Douglas haha good shit
Posted: Tue Nov 03, 2009 8:14 am
by MikeyMeyagi
block has 130k on it and it came out of a 4eat car.
i really hope thats not the prob but ill check.
Posted: Tue Jan 26, 2010 7:57 pm
by MikeyMeyagi
FIXED.
it turned out it was oil pressure pushing the seal out. after it popped out again i pulled the oil pump off to inspect it, and found 2 of the 5 phillips head screws that hold the cover on the back of the pump were backed about half way out. i never had the pump off previous to this, so ive got no idea how they loosend up. but its fixed and i have better oil pressure, WIN.
Posted: Wed Jan 27, 2010 7:41 am
by RJ93SS
i had the exact same problem. the culprit was non oem seals
Posted: Wed Jan 27, 2010 7:34 pm
by kleinkid
I think that those bolts backing out is a known discrepency. Probably a good idea to use Locktite on them when you have access to the pump. I think/hope I did.
