center diff swaping
center diff swaping
can you swap the center diff from a '91 legacy MT to a 2002 WRX MT to keep the 3.9 rear diff?
VF43 custom FMIC APEXI intake Invidia 3" TBE JDM Ver. 4 RA STi trans (4.44) SPT short shifter rear LSD WRX rear axels coilover suspension JDM 4-pot front brakes drilled slotted rottors Greddy EBC tuned 20G ECU sti 550cc injectors Jecs MAF walbro 255
Nope you can't sorry to say. The center diffs are different. Your center diff is a phase I and a WRX center diff is a phase II diff.
Isn't the wrx one 3.54, 3.45 or something I forgot which one. Some one else I'm sure will jump in.
There is a thread around here showing the difference between the center diffs.
93 Imp wag, 94 Imp wag WRX swap, 99 Imp Sedan WRX swap, 01 Imp Outback Sport, 05 Outback XT, 00 Outback, 98 Outback, 93 Leg touring, 93 Leg wag, 94 Leg wag lifted ej22t swap, 79 Brat 4x4 EA81 4spd d/r swap, 97 Crown Vic lifted
Can't you take the transfer gears from the SS 5mt and put them in the WRX 5mt?
