Little Downpipe work
Posted: Tue Jan 05, 2010 4:28 am
by Josh222
Almost time for the turbo back to go on :D
All done :)
Posted: Tue Jan 05, 2010 5:20 am
by 93forestpearl
Nice work. What cat is that? I've thinking about the metal substrate cat my self.
Posted: Tue Jan 05, 2010 5:23 am
by Josh222
It is a Magnaflow #59959 its 8" long with 3" in/out, the cat part is 4" dia.
Posted: Tue Jan 05, 2010 6:24 am
Yeah, very nice work!
Posted: Tue Jan 05, 2010 6:46 am
by Josh222
Hopefully my placement of the O2 bungs will work out. One on top is for the stock narrow band and the one off to the side with the plug is for a wideband O2 sensor when I get one of those.
Posted: Tue Jan 05, 2010 4:28 pm
by cj91legss
That's pretty badass man, good job
Posted: Tue Jan 05, 2010 5:09 pm
by kimokalihi
I have that same cat and also a couple of O2 bungs with plugs that need to be welded into the top of my 3" DP. I wonder if I should have them weld the cat in there while they're at it? Do you think an exhaust shop would do a good job with that though? I don't want stress cracks in my downpipe because of a poor weld job and I think the DP is not only strong but thicker than the cat (I think).
Posted: Wed Jan 06, 2010 1:03 am
by Josh222
The 3" ID (inner Dia) ends of the cat are long enough so that you can overlap the joint slightly when you put the 3" OD(outer dia) ends of the downpipe into the ID Cat so it won't break. I have never dealt with car exhaust shops but I assume they can do most of what Truck(big rig) exhaust shop can do which is where I work.
The cat is 8" long with ruffly 1" long 3" ID ends so I only cut out about 6.5" out of the downpipe so that I have a 3/4" overlap inside the cat so I won't get stress cracks.
Re: Little Downpipe work
Posted: Sat Apr 03, 2010 6:41 am
by Josh222
working on the install.
Posted: Sat Apr 03, 2010 12:29 pm
by kimokalihi
Damn, looks really nice. Want to weld mine? lol I still need to do it and soon.
Posted: Sun Apr 04, 2010 4:24 am
by Grayguy
Looks nice.
Why do you have so many templates/brackets (I assume that's what they are?) tacked to your welding table?
Posted: Sun Apr 04, 2010 4:39 am
by 93forestpearl
^ Looks like a jig to keep everything lined up nicely.
Posted: Sun Apr 04, 2010 4:52 am
by Grayguy
I prefer just to tack everything well enough in the car that it wont move. As dumb as it seems, I hate welding things to my welding table.
Posted: Sun Apr 04, 2010 3:01 pm
by Josh222
I work at a truck exhaust shop. We have hundreds of jigs and samples from the big trucks. Someone will bring a pipe to us and if we don't have a jig for it we weld up a jig to one of the benches and make a new one from the jig welded to the bench. In the case of my parts my wagon is at home with no plates on it and the welder is at work.
