Idler pully broke
Posted: Sun Jan 10, 2010 9:41 pm
by oldbugeye
Yesterday I was driving about 35mph in my 92 legacy turbo when I herd a pop and the car died. I popped the hood I could see the timing belt, it broke the timing cover
. So we took it home on a toe rope. I took of the timing coves to find an idler pulley in peaces in the case. So my question is is the motor ruined did it bend the valves at all?
Posted: Sun Jan 10, 2010 9:50 pm
by suba
Someone correct me if I'm wrong but I believe that your engine should be non-interference so there shouldn't be any damage to the valves.
Posted: Sun Jan 10, 2010 10:00 pm
by ericem
^^ your 100% correct non interference.
Buy a cheap good kit like this. Has a Japanese belt, and the idlers were japanese too.
click me
Use your original bolts!
Posted: Sun Jan 10, 2010 10:17 pm
by oldbugeye
Its good to hear that my motor is ok. So a new belt and new idlers and it will be OK That scared the shit out of me I thought the motor was toast.
Posted: Tue Jan 12, 2010 4:57 pm
by macipusy
Replace all the idlers as well as the tensioner pulley. It might be a good idea to do the water pump while you are in there....depending on when it was done last.
Posted: Fri Jan 15, 2010 10:05 pm
by supra90turbo
The cog-idler blew up on my white legacy last fall. The belt didn't jump, but it was real close!
Wish I could have gotten one of those kits when I did mine, didn't pay much more than that, but every bit counts!
