TMIC on ej22t '92
Posted: Sat Feb 06, 2010 3:57 am
by TheUhrinator
So, I have a '92 leggy with the ej22t engine. I would like to put on a TMI. What should I look for that would fit my car without any major modifications? I'm looking at getting the apexi boost controller and would like to have some extra cooling. I'm hoping to get just an air to air, if you think that this is going to be enough. Also, what else besides the intercooler and boost controller should I do? Any Help is appreciated, thanks.
Posted: Sat Feb 06, 2010 4:25 am
by Apex3
Search for TMIC or intercooler, there's a ton of threads on it.
IIRC the 02-03 WRX intercooler fits with little modification, the 04-07 with a little more. And a lot of people use some sort of saab intercooler too
EDIT: got that backwards
Posted: Tue Feb 09, 2010 6:28 am
by TheUhrinator
How would the 05 STi intercooler fit / What would I have to do to make it fit?
Posted: Tue Feb 09, 2010 6:35 am
by RJ93SS
Apex3 wrote:Search for TMIC or intercooler, there's a ton of threads on it.
it's kinda the other way around.
the sti intercooler is too large for your car.
02-05 wrx intercoolers fit but not well. 06-07 wrx and 07- forrester i/c's fit really nice.
do a turbo swap at the same time,. check it out, there's lots of write ups.
Posted: Tue Feb 09, 2010 6:46 am
by TheUhrinator
Posted: Tue Feb 09, 2010 6:57 pm
by BSOD2600
Yes, a td04, td05, or vf39 are very commonly swapped into our cars -- when using a TMIC.
Posted: Wed Feb 10, 2010 1:47 am
by Apex3
RJ93SS wrote:Apex3 wrote:Search for TMIC or intercooler, there's a ton of threads on it.
Oh crap sorry, you're right
Re: TMIC on ej22t '92
Posted: Tue Mar 23, 2010 3:08 am
by TheUhrinator
Another question that Dad has and I'm not positive about:
Do you have to do any extra tuning when putting an intercooler on? Simply, will the computer be messed up, or will it all go on no problem?
Posted: Tue Mar 23, 2010 3:17 am
by SLODRIVE
You should be good to go if you're running the stock turbo or a TD04, and stock or near-stock boost levels.
Posted: Wed Mar 24, 2010 7:45 pm
by Mattheww044
Yea, I am using the vf11 with a TMIC just fine. I have a TD04 but I still need all of the gaskets and stuff.
I am running 13psi on the TMIC'd VF11, walbro 255, 3" TBE, K&N. No problems related to any of that, but I have a leaky injector, time for the 440's! Just set ur boost at or under 13psi so you don't hit fuel cut (not a good feeling).
Posted: Mon May 17, 2010 5:52 am
by crashnburn
I have a top mount Intecooler that was in my legacy for sale. I believe it was from a 06 WRX. I just upgraded to a CXRACING FMIC. check out my pics for fitment.
http://bbs.legacycentral.org/viewtopic.php?f=15&t=44003
