knock sensor?
Posted: Tue Feb 16, 2010 2:23 am
by josh_90_leg
So my knock sensor is going out and of course the check engine light is goin on and off when it wants to, i was wondering if it should be fine to drive another few hundred miles till i can fix it....it shouldnt be messing anything else up or have any other problems should it? its coming on more frequently now too....
Posted: Tue Feb 16, 2010 2:33 am
by mike-tracy
You'll be running rich with a faulty knock sensor signal, but shouldn't be a big problem.
Posted: Sat Feb 20, 2010 1:21 am
by ciper
And you will be running with absolutely crap timing so the car will feel slow. It would probably run fine on 80 octane fuel like this lol
Posted: Sun Feb 21, 2010 3:38 am
by tahiti350
I drove from Oregon to Texas with a bad knock sensor... car would rattle on hard pull, onramps, etc... BUT got an average of 32 MPG for the trip.... I also had one injestor that started dying at idle going thru Salt Lake City, ran fine off Idle, so I kept going.
It definately WASN'T pulling timing...
Posted: Sun Feb 21, 2010 5:31 am
by BSOD2600
I can say with 100% certainty (via lots of data logging), that when there is lots of knocking, the ECU WILL reduce the "octane factor" parameter and the "knock retardation" parameter will increase. Once octane factor falls below 25%, extra fuel is added (WOT is about 1 AFR more rich) . Timing map is also reduced when its not at 100% either.
Posted: Wed Feb 24, 2010 5:25 am
by tahiti350
IF the knock sensor registers the knock, which it appears mine didn't
Posted: Wed Feb 24, 2010 5:31 am
by ericem
On a N/A car I think it doesn't affect it much. I remember on my N/A when I replaced the cracked knock sensor made no difference.
Posted: Thu Feb 25, 2010 7:01 pm
I can tell you when I was "testing" my knock sensor and trying to make it not as "sensitive" when I was non-turbo, it tweaked out and made the car run like poo. I had no power, and it threw a CEL.
Posted: Fri Feb 26, 2010 3:28 am
by douglas vincent
Poo don't run.....
Posted: Fri Feb 26, 2010 3:43 am
by Josh222
douglas vincent wrote:Poo don't run.....
I'm sure if you ate some mcdonalds it will
