CES test-pipe removed, cat installed Lots of pics + vid
Posted: Sat Feb 27, 2010 10:57 pm
by magicmike
Posted: Mon Mar 01, 2010 3:46 am
Very cool Mike, and good documentation!
I'm curious to see how it sounds with the test pipe.
Where did you get the 3" gasket. I've found a few places but they're not cheap....
Also....that test pipe was yucky...even for SS.
Re: CES test-pipe removed, cat installed Lots of pics + vid
Posted: Wed Mar 03, 2010 8:51 pm
by magicmike
Did you watch the video? Its sounds pretty similar. Without the cat it sounds more raspy like racecar sounding. sounds smoother with the cat.
I got the gaskets and flanges from FRSport.com Here are the gaskets:
http://www.frsport.com/FRSport-3-Inch-- ... _1305.html
At 7.95 each not bad at all but the shipping will be around 10 bucks.
2BOLTGASKET 2 $7.95 $15.90
Flanges 2 $9.60 $19.20
Subtotal: $35.10
Shipping cost (UPS Ground): $11.39
Total cost: $46.49
The Cat cost me $69.02 with free shipping.
So the total project minus the welding wire
cost me:
$115.51
As for the test pipe, the whole exhaust is covered in tranny fluid. The 4EAt is completely wet but its not leaving any pools under it in the driveway or in the garage. It cleaned up pretty well with the simple green and a wire brush.
Posted: Wed Mar 03, 2010 9:07 pm
by Adam West
Mike you are magic! Yes, if someone is thinking of having a shop do it 3" flanges aren't usually stocked - also that shape too.
Rock on! You don't have that sweet reek anymore which is nice with probably zero power loss...
Posted: Fri Mar 05, 2010 6:48 pm
by georryan
I decided to put on a high flow cat after my friend said he was getting a headache from driving behind me on a spirited run. =)
Posted: Fri Mar 05, 2010 7:32 pm
by Adam West
Yeah I experienced the same on group drives. Remember stopping in a big group on the way to a WCSS and getting pretty much stunk out. As much as I love the test pipe sound I swore I wouldn't do the same when I got my 3" put together.
Posted: Fri Mar 05, 2010 7:38 pm
Yeah I can't stand the stink of non catted cars.
Posted: Sat Mar 06, 2010 5:27 am
by RJ93SS
mmm, love that smell, like an old V8.
Posted: Mon Mar 08, 2010 3:11 pm
by yazmo
what do the test pipe exactly?
Posted: Mon Mar 08, 2010 7:51 pm
It installs in place of the catalytic converter section.
Posted: Thu Mar 11, 2010 1:22 am
by magicmike
yazmo wrote:what do the test pipe exactly?
Its called a "test pipe" because you aren't legally supposed to use it on the road, in other words, without the cat installed. Test pipe meaning that you would pull out the cat and install this straight pipe in its place to reduce the restriction.
Posted: Wed Aug 18, 2010 2:09 am
by 92legacyss
How long was the Test pipe or cat that you installed, i'm about to do my exhaust and i need to lengthen my midpipe.
Posted: Wed Aug 18, 2010 6:03 pm
This test pipe is just for the CES system. So it may not provide the information you're looking for.
I can take a measurement of the test pipe length when I get home.
Posted: Wed Aug 18, 2010 9:53 pm
by 92legacyss
Is your whole TBE custom for your car or is it a modified WRX setup?
Posted: Thu Aug 19, 2010 6:21 pm
It's made by a company in Australia called CES.
http://www.cesracing.com.au/
The whole TBE is made for the turbo Legacy.
http://main.experiencetherave.com/subar ... s/ej22t/25
