Head Identification?
Posted: Tue Mar 02, 2010 7:37 am
Okay, I've read through the DOHC thread a few times and I'm getting dizzy...
I'm basically trying to sort out which heads I have on my car. I initially thought they were EJ20k which turns out they are not. I should have actually caught this a long time ago if I'd been paying more attention. I'm trying to sort this out so I have a better feel for my compression ratio and any type of valve/cam requirements.
What I know -
They are definately twin turbo heads - have the second coolant port on the driver's side head.
I have the metal timing gears, though I know these could have been swapped over.
They are coil on plug heads.
The valve cover gaskets match a 96' Legacy GT.
The coolant crossover pipe looks similar to the EJ20h but it does not have a spot for the single spade temp sensor. The flat spot is there but it has never been machined or drilled. There is also not as much 'flashing/web' between the passenger block port and the pipe going up towards the radiator.
The passenger side rear timing belt cover does not look like the Legacy EJ20g. I'm hesitant to use this as my identifier as the top gear mounting hole does not line up with the block. By this I mean the hole in the plastic cover beside the top gear does not line up with the block, there is a vertical offset of about 3/8". The bottom lines up though.
The turbo coolant pipe coming off the crossover matches the picture for the EJ20h but the one coming off the blcok does not.
I'm a little stumped as nothing perfectly matches the pictures in the DOHC thread and wondering if there are any other firm indicators of which heads I have.
Any and all help is appreciated.
What I know -
