weird Jerking problem... Help???
Posted: Sat Mar 06, 2010 12:30 pm
by SubyFusion
i have a 1992 legacy ss 5mt N/A and i have a weird problem! when im driving freeway speeds its fine but when i hit stop and go traffic my car jerks when i let off the gas and when i go to accelerate it jerks again like the clutch isn't grabbing but it feels like the engine. so im confused any help would be vary appreciated thanks
Re: weird Jerking problem... Help???
Posted: Sat Mar 06, 2010 11:12 pm
by Mattheww044
the SS is the turbo version of the legacy... is yours the turbo or N/A?
Posted: Sun Mar 07, 2010 1:57 am
by SubyFusion
sorry i meant S as in sedan its an N/A thanks for the reply i am new here so any info on the problem would be greatly appreciated =)
Posted: Sun Mar 07, 2010 6:59 am
by SubiePrice88
hmmm...you wouldnt happen to have a Check Engine light on?
Posted: Sun Mar 07, 2010 8:34 am
by Mattheww044
oh ok, just wanted to get that cleared up. Yea as SubiePrice88 said, do you know how to check your codes?
Posted: Sun Mar 07, 2010 4:39 pm
by 86ruguy
mine's doin the same thing. and i have no CEL on.
Posted: Sun Mar 07, 2010 7:35 pm
by SubyFusion
yes the check engine light comes on but its weird because it only comes on when i hit stop and go traffic and then when i get back up to freeway speeds it goes away.... and i tried to test 4 it but i cant because it disappears. When i am speeding up and slowing down a lot the light will come on and then the car seems to jerk like its engaging the clutch when i hit the gas or something witch doesn't make sense because thats not possible but thats what it feels like it also happens when i slow down its like a bucking kind motion. so i hope that helps any info??? thanks= )
Posted: Sun Mar 07, 2010 8:12 pm
by SubiePrice88
Here is how to check the codes and clear them:
http://www.surrealmirage.com/subaru/engine.html
Posted: Mon Mar 08, 2010 8:17 am
by SubyFusion
well that would help if the code stays but it goes away= ( it sucks i was driving today and i hit traffic and bam the CEL goes and when i slow down and speed up it jerks like crazy! i was having some problems with the Knock censer a while back but i put a new one in and cleared the ECU! i was thinking it could be the KS again but its not throwing the code and i don't think it would cause that kind problem it seems like it has something to do with the throttle maby??? not sure so i am still stuck any any more info on the problem...thanks
Posted: Mon Mar 08, 2010 9:12 am
by SubiePrice88
what do you mean by the code goes away?
Posted: Mon Mar 08, 2010 6:42 pm
by SubyFusion
ok so originally it wasn't showing any codes when i checked the memory so i thought it wasn't storing it in the memory but now its showing a code 42 witch is the Idle Switch! thanks 4 the link SubiePrice88 = ) so now that i finally know what it is can any one give me some info on the problem???? dose this happen often? Thanks
Posted: Tue Mar 09, 2010 3:25 am
by SubyFusion
Is the IAC valve the same thing as the Idle switch???
Posted: Tue Mar 09, 2010 4:17 am
No, the idle switch is built into the throttle position sensor.
Posted: Tue Mar 09, 2010 7:16 am
by SubyFusion
well the ECU is throwing a code 42 witch is the Idle switch, is there any way to fix it? i am not sure what to look for..
Posted: Tue Mar 09, 2010 7:10 pm
Test/adjust the Idle switch using these instructions.
http://www.main.experiencetherave.com/s ... sting3.jpg
If you still have the code, you may need to replace the throttle position sensor.
