Page 1 of 3
				Rotating Pictures - New Style
				Posted: Sun Mar 07, 2010 11:05 pm
				by DLC
				All previous rotating pictures are now defunct.  The new style allows for much more space, and we're going to take advantage of it.
Here is how to submit your image for use in the rotating banner:
Image must be at least 950px wide and 180px tall, preferably larger so there's some room to work with.
The transparent grey box will be incorporated into the final image, so keep that in mind.  Getting a picture where your car is NOT filling the entire frame would be best, and if it's in the left half it would work even better.  Taking a picture from a distance is necessary if you want your entire car in frame.  Example:
The end result will be something like this:
email me your picture (legacycentral at yahoo) and I'll put it up.
				Re: Rotating Pictures - New Style
				Posted: Mon Mar 08, 2010 8:17 am
				by Mattheww044
				i need tires so I can put my wheels on, and some tint, and then im in for sure!
				Posted: Mon Mar 08, 2010 7:44 pm
				Dave,
Do we want to have them put their username text on as well like last time?
				Posted: Mon Mar 08, 2010 9:02 pm
				by DLC
				I'm going to have to manually do all of these, so it's not going to be as flamboyant or expressive as it was in the past.  Usernames will (probably) all be the same size and in the same spot, likely in a corner with the same kind of shaded block as the forum name and description.
This is probably the best way to maintain a homologous look while getting a picture up there
				Posted: Tue Mar 09, 2010 4:43 am
				Well....none of the pictures I have will really work....They're all mostly too zoomed into the car.  Guess I'll have to take some more...hahaha
				Posted: Tue Mar 09, 2010 5:34 am
				by DLC
				A little cropping never hurt, but for the best fit, one from a bit of a distance is best.
				Posted: Tue Mar 09, 2010 6:24 am
				by subaru_styles
				yep..the only non zoomed in pic my car is on the right half..would that work?
sending a couple your way
				Posted: Tue Mar 09, 2010 11:05 am
				by Brunt
				if your car is on the wrong side you could just mirror the image.  you might be able to tell that a badge or text is backwards, but i don't think most people would even notice.
				Posted: Tue Mar 09, 2010 8:40 pm
				by DLC
				Added four new.
				Posted: Thu Mar 11, 2010 1:32 am
				by magicmike
				Dave,
Is there a image file size restriction like before on this new size?  I'd imagine you are having to photochop these up so you will be able to compress on your end but I thought I'd ask.
				Posted: Thu Mar 11, 2010 1:34 am
				by DLC
				I'm not nearly as concerned about image size as before.  I am actually not using Photoshop, but Paint.NET, as it's far simpler (and cheaper).
All I need is an image that's at least as large as the dimensions in the first post.  I'll take care of the rest.
				Posted: Thu Mar 11, 2010 5:46 am
				by SiCkSTi04
				email sent Dave!
				Posted: Thu Mar 11, 2010 7:50 am
				by skid542
				Dave, you have another email.  Many thanks.
				Posted: Thu Mar 11, 2010 7:22 pm
				by Kelly
				Uno pico el sento
				Posted: Thu Mar 11, 2010 7:25 pm
				by sqc151
				cant wait to get my new ride... ugh, the agony of waiting...lol
				Posted: Fri Mar 12, 2010 1:08 am
				by SubiePrice88
				e-mailed!
				Posted: Fri Mar 12, 2010 1:46 am
				by DLC
				All submissions have been added as of this post.
				Posted: Fri Mar 12, 2010 2:26 am
				by ciper
				I made mine the exact dimensions you wanted
From what I can tell all the pictures currently in rotation are around 30k. I made mine higher quality so you could add the grey boxes and then compress it.
				Posted: Fri Mar 12, 2010 8:20 am
				by 93forestpearl
				Email sent
				Posted: Sun Mar 14, 2010 9:31 pm
				by DLC
				All submissions have been added.
				Posted: Mon Mar 15, 2010 2:44 am
				by beatersubi
About time I joined in on this party. Does this sized image work?
				Posted: Mon Mar 15, 2010 10:21 pm
				by DLC
				Yeah, that size is fine, but sans text.
				Posted: Mon Apr 19, 2010 8:34 pm
				by LookAsubie
				Email sent
				Posted: Tue Apr 20, 2010 11:24 pm
				Posted: Sat Jun 05, 2010 9:01 am
				by ashergrey
				Hey Josh, just noticed you posted here on my behalf.  Thanks for that.
Emailing Dave a copy of the photo flipped has been on my to-do list for weeks but I'm just getting to it now.  I haven't seen my pic come up in rotation so I assume DLC hasn't had the chance to do my job for me.
So... email sent.
