I checked the Ohms on my TPS vs FSM and they are as follows:
No2-No3 - FSM 12 kOhms, TPS reading 9 kOhms
No2-No4 - closed - FSM 10-12 kOhms, TPS reading 8.56 kOhms
No2-No4 - open - FSM 3-5 kOhms, TPS reading 1.82 kOhms
What kind of issues would this cause. I've been having idle issues and stalling / no start issues.
Do I just adjust it, or replace it?
TPS resistance readings - is this bad?
maciek puszynski
16 WRX | 6mt | fa20
2.36L Turbo - RSTi Build
16 WRX | 6mt | fa20
Re: TPS resistance readings - is this bad?
Those are close to the readings. The only thing you can or should adjust the TPS to is the idle closed switch.
http://www.main.experiencetherave.com/s ... sting3.jpg
Thanks for the tip....I checked it and it was within specs. I also doublechecked other TPS sensors on extra Tleg manifolds I had lying around, and they both were close to my original readings.
maciek puszynski
16 WRX | 6mt | fa20
16 WRX | 6mt | fa20
Lunatech
While your at it maybe you could get a resistance reading from the IAC for me, THANKS.
Robert,
Rio Red 1990 L sedan 5MT at least 302000 mi. and Spruce Pearl 1996 Wagon 4EAT 245000 mi.
georryan wrote:
Don't knock him for thinking outside of the box. At least he has been creative.
Legacy777 wrote:Those are close to the readings. The only thing you can or should adjust the TPS to is the idle closed switch.
josh i try to do this but seriously is this possible without removing the throttlebody
there is no room to insert gauge and keep it straight,
What type of gauge do you have? I was able to get it inserted to do the measurements
'11 WRX Limited
'94 TW | R.I.P.
how did you hold it? ill get a picture of me trying to place the gauge you will see what i am trying to say.
its like impossible lol
The gauge should stay by itself with the force of the TB plate springing back shut. You need to use the tiny feeler gauges.
maciek puszynski
16 WRX | 6mt | fa20
16 WRX | 6mt | fa20
