SOLD! FS: 93 Legacy LS wgn, cheap transportation or part-out
Posted: Sat Mar 13, 2010 10:43 pm
Am going to try this route first instead of just turning it in for salvage value as his car insurance totaled it out....
1993 Green Subaru Legacy LS Wagon
Good:
New timing belt..battery..alternator..keyless entry..K&N air filter..front strut bar..sunroof(resealed by PIA)...all work also done by PIA..took stereo out but will have an older Alpine deck to be installed an probably a pair or two of decent non factory speakers...cruise...if weathertech mats won't fit in new Outback will also include them...will come with Outback two-tone wheels and General Altimax HP tires which are rated reall well by Tirack and us consumers...newer plug wires...factory power antenna...magnaflow muffler---sounds pretty nice...also comes with set of factory alloys with studded tires....also has the black plastic cargo liner...
Bad:
Rear-ended...hatch is pushed in and jammed shut, right tailight is toast as is bumper...can email pics if desired..
All other lights fine, everything works the way it should. Nice cold air and nice hot heat, warms up pretty quick.
Car ran and still runs fine, 152,000 miles. Clean current title, call Steve at PIA if you want to verify. I do have all receipts for work done.
$500 and its yours, with all the recent engine work and keyless entry and such I would love for it to go to someone rather then being scrapped. Great lst car for someone!
Good:
Bad:
