WTB oil pan for ej22t
Posted: Sat Mar 20, 2010 7:03 am
by yazmo
hi guys i am wondering how a oil pan would cost apprx.
or if anyone as one for cheap, today i hit a big rock and my oil pan is in bad shape but not leaking
So if anyone as one pm me!
Re: WTB oil pan for ej22t
Posted: Sat Mar 20, 2010 2:17 pm
by evolutionmovement
I think I paid $80 for a new one.
Posted: Sat Mar 20, 2010 5:05 pm
by SLODRIVE
There is no specific pan for an EJ22T. Virtually any EJ series pan will fit just fine, just make sure and use the pickup that goes with the pan just to be safe...there's a couple different styles.
Posted: Wed Mar 24, 2010 3:57 am
by ciper
What slodrive said. I personally vote for an 05-07 "sti" style pan (which is used on many other models)
Posted: Wed Mar 24, 2010 5:16 am
by EJ KILLA
if subawho isnt buying my stuff i got an oil pan for you
Posted: Wed Mar 24, 2010 6:21 am
by ericem
go to the dealer it was only $60 here for mine. In usa should be even cheaper. I do not recommend a STi pan, you will need a STi pickup as well and STi pickups tend to break easily.
Posted: Wed Mar 24, 2010 7:01 am
by yazmo
thx you guys this is helpful . is its dangerous is this as raise a little over the full on the dip oil stick since the oil pan is bump the level of oil is higher.
should i remove some oil?
i will look on dealer here for the oil pan is there a gasket that i need with?
Posted: Wed Mar 24, 2010 8:59 am
by ciper
yazmo wrote:thx you guys this is helpful . is its dangerous is this as raise a little over the full on the dip oil stick since the oil pan is bump the level of oil is higher.
I run all my cars way over the full mark, at least five quarts. The pan itself holds more than five quarts.
There is no gasket. You use the grey sealant stuff like the other engine parts call for.
ericem wrote:go to the dealer it was only $60 here for mine. In usa should be even cheaper. I do not recommend a STi pan, you will need a STi pickup as well and STi pickups tend to break easily.
I thought that was only on the early pickups?
