Engine Management......help
Posted: Sat Apr 03, 2010 1:38 am
by scoobyleg1
So I have a 93 turbo legacy wagon and I need someway to tune my car.
My mods are:
TD05H 18g
MRT frontmouont
Apexi SAFC
Apexi electronic Boost controller
5 speed manuel trans with 06 wrx gears and syncros.. 390's
WilWood Big brake kit 6 Piston calipers
BPM Up pipe
Megan Turboback exhaust
stage 2 clutch
light weight flywheel
custom intake
KYB ajustable struts all around
What are my options?
Re: Engine Management......help
Posted: Sat Apr 03, 2010 2:03 am
by sqc151
that list sounds tasty. id like to see some numbers.
Posted: Sat Apr 03, 2010 3:54 am
Depends on what you want to do.
There are piggy backs, Perfect Power and few others.
Revtronix has a chip...however they haven't been heard from in a while.
Then there is stand alone EM like Link, Autronic, & Haltech. I've got a Link, and there's a few other members that have Links, and Autronics.
Unfortunately there's not an easy engine management solution
Posted: Sat Apr 03, 2010 5:18 am
by scoobyleg1
which model from PP would you suggest
Posted: Sat Apr 03, 2010 5:23 am
The perfect power 6 is what has primarily been floating around the legacy crowds. I'm not sure if they have a newer verision or not.
Posted: Sat Apr 24, 2010 4:24 am
by scoobyleg1
So Im going to go with the PP6/SMT6 for my 93 turbo wagon.
which injectors should I run with my TD-05h 18g?
Options:
Grey sidefeed 440's
Yellow sidefeed 560's
Posted: Sat Apr 24, 2010 4:27 am
by 93forestpearl
Ge the largest injectors you can tune for. It is always good to make a fuel wall if you overboost.
I kicked myself with my first set which were 650's. Now I have 900's and want 1600's.
