Good alignment settings for aggressive daily driver / autoX?
Posted: Tue Apr 06, 2010 10:29 am
I did a suspension upgrade a few months back that included:
-2005 Legacy GT front struts
-2004 Sti springs on all 4 corners
-2004 STi rear struts
-1997 Legacy GT front sway bar. (20mm)
-1991 SS rear sway bar (19mm)
-1997 Legacy GT 16" wheels with 205/55/16
-stock brakes
The rear sits a little higher than the front but less than an inch. I may relocate the rear mounts a bit to compensate.
I set the front camber to maximum on the stock parts.
The control and cornering is WAY better than stock. I get just a little bit of oversteer in hard corners after I load the suspension.
I haven't taken it in yet to get an alignment (and I know it needs one) because I first want to see what you guys think is the best for a car that frequently sees WOT corners, 120mph+ and heavy braking. I don't participate in the rallyX anymore due to the lowered ride height of the car (and the way the local rallyX is managed) but I would like to get involved in the autoX and roadracing.
Tire wear is not a major issue for me.
What do you guys think?
-stock brakes
