ABS light after master cylinder replacement
Posted: Thu Apr 08, 2010 6:01 pm
So I recently replaced the master cylinder in my '93 SS with a remanufactured unit, and will soon be replacing that one with a new unit. Everything went smoothly, and I had to drive on it for a work day without flushing the fluid due to running out of time in the shop. No ABS light that whole day. The next afternoon I flushed the entire system with new fluid, got all the air out, etc.. I bled the ABS unit as well. Everything seems ok until I accelerate quickly or brake urgently and then the ABS light pops on.
I feel like it might be a G-sensor issue but if anything the car stops slower now but with a firmer pedal...
Is there a special bleed procedure that isn't mentioned in the service manual?
The car appears to have the Bosch system.
Thanks,
Parker
Thanks,
Parker
