Simulated narrowband to replace OEM o2 sensor?
Posted: Sat Apr 10, 2010 5:17 pm
by sobe_death
I know some cars are very sensitive to it, but is there any negative effect from using the simulated narrowband output from a wideband like the LC-1 to replace the factory o2 sensor?
Re: Simulated narrowband to replace OEM o2 sensor?
Posted: Mon Apr 12, 2010 12:00 am
I'm not aware of any negative effects.
Posted: Tue Apr 13, 2010 4:46 am
by BSOD2600
If for some reason your wideband goes AWAL, then it'll obviously be sending screwy readings to the ECU which will adversely affect drivability/fuel economy.
I say this because 2x over the course of my LC-1 history, it's "lost" its AFR settings. This causes the XD16 gauge to display crap. Have to use their programmer tool to re-set the AFR setting for 'gas'.
