which clutch?
Posted: Sun Apr 11, 2010 12:28 am
by Weazel240
Ej22t engine, with a 95 impreza cable outback trans.
Can i use the wrx exedy oem set up?
Re: which clutch?
Posted: Sun Apr 11, 2010 11:58 pm
No you can not. You need to use a push style clutch setup. I had heard the WRX did go to push style around 06, but don't know if that setup could be used on the older push style clutches.
Re: which clutch?
Posted: Mon Apr 12, 2010 12:42 am
by Weazel240
what would be a push style?
the 2.2 non turbo BUT upgraded? 2.5 RS upgrades?
Like exedy, act, for 2.2/2.5rs?
Re: which clutch?
Posted: Mon Apr 12, 2010 1:52 am
Push style is the type of engagement action of the clutch & fork setup. Typically the push style is found on non-turbo cars and the pull style found on the turbo cars. However, like I mentioned, I think Subaru may have switched to the push style for the WRX in 06 or around there.
I'd look for an exedy for a 2.5 rs. That should work. Only thing I'd be cautious of is the 2.5 RS's use a hydraulic setup, so they may have stiffer pressure plates, which may make the clutch pedal rather heavy for a cable clutch.
Re: which clutch?
Posted: Mon Apr 12, 2010 3:41 am
by Weazel240
thanks for the help.
yeah i was really confused about which clutch to go with.
So ill search for a 2.5 RS clutch.
Re: which clutch?
Posted: Mon Apr 12, 2010 7:52 pm
by n2x4
I'm running a 2.5L Forester Exedy clutch in my 2.2t powered car with a 95 Impreza cable trans. Clutch pedal feel is fine and I've had 0 issues with holding power at 12PSI on a VF10 turbo. I autox and drag race the car regularly.
Josh is correct about the clutch changeover in 06 for the WRX. Word on the street is that the 06 WRX flywheel must be sourced in order to use the corresponding clutch.
Re: which clutch?
Posted: Tue Apr 13, 2010 1:24 am
by Weazel240
What year 2.5L forester is the clutch for?
and how is the tranny holding up?
Re: which clutch?
Posted: Tue Apr 13, 2010 4:15 am
by n2x4
Exedy P/N is KSB04. Trans is doing fine. I do my best to be easy on the launches, only launched at 4K rpm once. It's all in how you treat it. Your mileage may vary!
