FS: RHD Wagon EJ20R 4.44 5 speed +more
Posted: Sun Apr 11, 2010 6:21 am
I tried selling this locally with not much interest so I am going to try here where there is more of a niche.
Car location: Tampa, FL
If I don't answer here the easiest way to reach me is via my email: Prowlafoci@gmail.com
If you would like pictures I can get them for you over the weekends when I go home from school, this would also apply to quotes on shipping.
What I have is a 91 Legacy Wagon, white, beat to hell.
I will sell the whole thing as a PARTS CAR ONLY, no title.
Or I will split it up and part out if there is interest in a certain thing, like 5 speed swap etc.
What I have roughly:
EJ20R with all the needed parts, all the hoses/vac/ecu both engine and front car wiring harness.
The catch; The timing belt slid off while idling due to what I am assuming was the tensioner failing. It didn't make it all the way off because i notice smoke from the belt burning through the covers. It seems like the compression is shot though.
EJ22 that was taken out when the EJ20R went in. It did start, idle, etc but never got to drive it due to the transfer case being broke.
The EJ20R's 5 speed, its a 4.44 and also have a 4.44 rear diff with all axles and drive shaft, would be good for a 5 speed swap.
I also have a lot of random parts
The stock auto drive shaft
The stock rear diff
Stock wiring harness's (whole car) and ECU/Trans ECU
02 WRX gauge cluster with ~15K miles
Sparco steering wheel adapter, works for legacy not sure if the spline is the same for imprezas
Also have a Sparco wheel if interested, both adapter and wheel are brand new.
Also have a STi radiator with around 15K miles, was MINT when I got it but from sitting around it has a few bent fins now.
This car has been sitting in my garage and it needs to go, throw me a reasonable offer if you are interested in something.
The stock rear diff
