EJ22t in peices, VF11
Posted: Sat Apr 17, 2010 5:43 am
I've got basically a complete EJ22t sitting in pieces in various places around my house, I was going to build a monster block but decided against it...
Parts I have from the EJ22t include the following. (which I would like to keep together)
heads, cams, gears, valve covers, intake manifold, fuel rails, injectors, engine harness, oil pump, water pump, block halves, crank, pistons, wrist pins, oil pick-up and pan.
Basically, it needs rebuilt, and new EVAP lines. I estimate that the motor only has about 30K miles on it, crosshatching is still visible.
I'd like 600 for all of it. Shipping would be a pain, but I'm not opposed to it at buyers expense.
I also have a VF11 with wastegate (Absolutely zero shaft play) make me an offer, I don't need it.
Oh, and I'm located in southern-ish Indiana.
Pictures will be added as I get time to take them.
