ECU pins for BCS?
Posted: Sat May 01, 2010 6:28 pm
After listening to the problems Gabe has had with the BCS I have realized that when I re-loomed my wiring harness and got rid of extra connectors I'd made a mistake. I cut the BCS connector off figuring since I won't be using it, I didn't need it. I failed to recongize that the ECU would be upset if it were missing, thinking I'd unplugged my a while ago without any problems.
So that brings me to today, since I now know I need to have it hooked up and finding the clipped wires will be tricky at best, I'm thinking I need to address the problem at the ECU.
Going through the FSM's I've found the reference to the BCS but I get referred to the SMJ page which I'm not seeing.
So the question is - what pin on the ECU controls the BCS?
Any help would be greatly appreciated.
Thank you.
Thank you.
