ej22t pistons
Posted: Sat May 01, 2010 9:33 pm
by EJ KILLA
so im curious, is there anything about the ej22t pistons that are special? are they made from a better material than other subaru pistons? are these notorious for breaking ringlands at all? i just had my ej22t pistons cryo treated to strengthen them even more....
Re: ej22t pistons
Posted: Sat May 01, 2010 10:34 pm
by gijonas
Most importantly they are made to allow the compression ratio needed for boost.
Re: ej22t pistons
Posted: Sat May 01, 2010 10:41 pm
by EJ KILLA
well i already figured that but would like to feel confident that these will hold 21 psi
Re: ej22t pistons
Posted: Sun May 02, 2010 1:46 am
by gijonas
:smt033 + :smt115 = :smt073 :smt076
But honestly Im pretty sure others have pushed them that far or more,as long as tuning is good,thats the key.
Re: ej22t pistons
Posted: Sun May 02, 2010 7:25 am
by douglas vincent
If NO detonation.... Yes...
Bad det? No ringlands....
Re: ej22t pistons
Posted: Sun May 02, 2010 8:18 am
by 93forestpearl
EJ KILLA wrote:well i already figured that but would like to feel confident that these will hold 21 psi
21 psi from what? You can make 21 psi from a TD04, or 21 psi from a 40R. They are worlds apart apart in airflow, which is what actually matters.
The 22T pistons are windowed, FYI. Keep them to less that 300 whp with excellent tuning, and you'll have a cushion.
Re: ej22t pistons
Posted: Sun May 02, 2010 6:48 pm
by EJ KILLA
welll these are in my h6, so the 21psi will be distrubeted over 6 pistons from a turbo off a 2001 dodge cummins.
Re: ej22t pistons
Posted: Mon May 03, 2010 2:06 am
by gijonas
No cigar,doesnt actually work that way unfortunately.The number of pistons does not give you any extra room for error.
Re: ej22t pistons
Posted: Mon May 03, 2010 6:22 am
by EJ KILLA
ha, well i blame mike-tracy for that statement lol.
Re: ej22t pistons
Posted: Fri May 07, 2010 6:09 am
by mike-tracy
EJ KILLA wrote:ha, well i blame mike-tracy for that statement lol.
Haha, blame perrin then. What I was referring to was Perrin talking about HP/cylinder when compared to smaller 4cyl's, the margin of safety, etc etc (under "Dyno Time!")
http://www.perrinperformance.com/pages/show/32
Re: ej22t pistons
Posted: Fri May 07, 2010 7:15 am
by EJ KILLA
" Think of this build as WHP per cylinders. 600WHP on the H6 is 100WHP per cylinder. 100WHP per cylinder on a 4 cylinder is 400WHP, which many consider and have proven to be safe (with non-forged piston engine). To get 600WHP on a 4 Cylinder you will be at 150WHP per cylinder. That is 50% more stress, and pressure. If we use the example of a forged piston, stock sleeved STI motor, holding almost 600WHP (150WHP per cylinder), the H6 would be good for at least 900WHP."
Re: ej22t pistons
Posted: Fri May 07, 2010 8:06 am
by 93forestpearl
Alright, you need to start over. First and foremost, you need to state a power goal. If you don't you are wasting a lot of time and money.
Why do I say that? Every decision you make depends on that.
Just because the shortblock can "handle" a certain amount of power does not mean the rest of your car can. Fuel delivery does not change it's requirements based on the number of cylinders. Neither does engine management. Nor does the clutch and transmission.
So, before you go any further, you really should put your goals down on paper. It will simplify soooooooo many things in the end, trust me.
Re: ej22t pistons
Posted: Fri May 07, 2010 8:20 pm
by EJ KILLA
well 400whp is my goal but if it is higher than great...
