I’ve only owned this SS for about a year. From the VIN history, I can see this SS originated from Portland, OR and has lived in OR, ID, and WA with 5 previous owners. The previous owner relayed a story about the grandma who first owned it, killed the tranny and got it replaced under warranty. It also apparently sat in a barn for a few years. I purchased the SS with a blown engine headgasket (sold it off). I transplanted all of the performance parts from my previous ‘94 TW to SS last summer. Like any old car, this one has various dings, scratches, etc but zero rust.
I have full maintenance records since 2006 (for the engine that I swapped into it). No CELs. The body has 231K miles. This is still my daily driver, so it works fine. Planning on posting the sale on Subaru forums (bbs and then nasioc) for a week or two. If no serious takers, then off to the wild world of Craiglist. Thinking about starting at $4,500. Located in Lynnwood, WA.
Performance
Walbro 255 fuel pump
Hallman Pro RX MBC
Group N Engine mounts (7/2009)
3” custom TBE + resonator
TD05H-16G turbo (part # 14412AA092)
2007 WRX intercooler
Samco TMIC hose, t-clamps, etc
Autecs MAF
JDM 440cc injectors (flow tested/cleaned at 432cc 11/2009) + new o-rings.
Revtronix Stage 2 chip – version 3 (this is the latest version of the chip released).
EvoScan USB data cable
Interior
Kenwood KDC-MP435U – USB/AAC/WMA/MP3/WAV CD Receiver with External Media Control, iPod, etc
Kicker DS600 speakers
Autometer boost gauge
Innovate LC-1 wideband and XD-16 digital gauge
Wired for amp in trunk
Exterior
2005 WRX wheels + 1 full size spare
205/55ZR16 Conti Extreme Contact DWS tires (8/2009). Approximately ~9K miles.
Maintenance
New speedometer cable (2007)
New NAPA starter (2009)
New 84 month battery (12/2007)
New alternator (8/2007)
New timing belt, tensioner, covers, front cam seals (1/2009)
New oil pressure switch (5/2009)
New rocker cover gaskets (5/2009)
New keys from dealer, cut from code (6/2009)
New ignition lock cylinder (7/2009)
New pads, rotors, calipers on FRONT (7/2009)
New synthetic tranny/diff oil (7/2009)
Alignment (8/2009)
New master clutch cylinder (8/2009), new slave cylinder (8/2007)
New coil pack (9/2009)
New fuel filter (9/2009)
New gas cap (9/2009)
Resealed sunroof (10/2009)
New knock sensor / wire (2/2010)
New spark plugs (2/2010)
New OEM cluster lights
Synthetic oil for the past ~20K miles.
Extras (not included but sold separately)
JDM 4.11 5MT turbo transmission with ~50K miles
2x VF11 turbos
OEM intake parts, tubing, connectors, etc
STI short shifter + adaptor couplings
Power steering pump refresh kit
Tire chains that fit 205/55ZR16 tires
Chris paiano FCD - http://fcd.chrispaiano.com
Known issues:
* front window cracked on passenger side
* body dents / hood scoop paint pealing
* needs new struts
* dome light stays on all the time – I have it switched off
* passenger door lock sometimes doesn’t actually lock for some reason
* trunk lock replaced with blank metal, as previous owner had it broken into.
* Power steering pump is weeping.
* PCV hose in left-rear engine is cracked, causes occasional oil to drip onto uppipe.
* ECU sees too much knocking even though none is audible. As such, ECU is in “limp mode”.
These are pictures from last summer. The WRX wheels are not installed. Yes, need to wash the car and get updated pictures...
