need some help thanks guys
Posted: Tue May 04, 2010 6:04 pm
hey whats up guys this is the set up im running
95 impreza coupe
EJ18bottom end
EJ22t heads and cams from a 94 legacy
cometic head gaskets
arp studs
long tube headers to custom up pipe. Turbo is mounted behind headlight
walbro 255 fp
375cc injectors> from a stock SR20DET
front mount IC
i was planning on running a Garret gt2860RS
but its just not in the budget right now...
i got my hands on a turbo brand new never used from a civic turbo kit for 200 bucks so i went with it...it was a eBay turbo its journal bearing im only need it to last till August but it has a .63t3 exhaust and a .50A/r compressor housing hoping to run 15psi to start maybe 20 after i break in the motor...
was wonding if i could use a ecu from a LGT
and have a manual boost controler to turn up the boost
also was wondering if the 375cc injectors are enough...i was trying to find the specs on the ej22t uinjectors and i saw they max out at 380cc ...i know for a fact that the sr20 375 will flow over 450 cc so i figured they would be good to start out with
thanks for everything
95 impreza coupe
EJ18bottom end
arp studs
walbro 255 fp
front mount IC
