JDM Cam sensor
JDM Cam sensor
Pictured as it sits in it proper location on the head, Which Terminal is Signal and Which terminal is Ground?
Re: JDM Cam sensor
For future reference this cam sensor will work you just have to use a Fuel injector plug. the shield doesn't matter too much because it's just a ground. if you were to splice the wire from a broken 3 wire plug(Stock) red goes on the Driver's side and White goes on the Passenger side.
I searched and found nothing like that so there ya go.
Re: JDM Cam sensor
That's cool to know. Thanks
