EJ20H Heads - PCV system
Posted: Sun May 23, 2010 7:45 am
I think this is a redudant question and I've read through a few threads including Vikash's classic PCV thread. I'm finalizing my engine bay and and ready to do the PCV system. I've got EJ20H heads so they only have the one vent per valve cover and my block has the forward crank breather vent pluged to allow the coolant crossover pipe to work.
I'm using a rotated turbo setup and the newer style stock 45 deg. intake box.
The plan is -
Tap and install a 1/2" nipple directly into the filter box, post filter, one nipple for each valve cover vent. This makes routing super easy and fairly clean.
I will have a T-fitting to tie the rear crank breather vent to the PCV valve. The other end of the T-fitting will go to a fitting I will place in the small length of pipe leading to the compressor inlet. I haven't quite figured it out yet but I will make this fitting have a small venturi effect.
So, at this point I should have fresh air available to the valve covers and have a vacuum being pulled on the crankcase - either by the venturi or the PCV.
This sound reasonable?
*One last question - any reason why the PCV valves at the generic auto-part stores wouldn't work or should I go OEM?
Thanks in advance. I'll have a new teaser pic mid week - the engine bay is starting to look pretty
The plan is -
