check out this turbo calculator on my EJ22T
Posted: Mon May 24, 2010 8:53 pm
by obd1-kenobe
Holset hx35 on a EJ22T making 350 at 74% efficency!
can my heads hold up or do I need 2.0 liter heads?
http://www.squirrelpf.com/turbocalc/ind ... p_sel0=113
when you get there hit REFRESH MAPS on the bottom to see the chart....
heres the map
http://www.squirrelpf.com/turbocalc/gra ... uct_id=113
Re: check out this turbo calculator on my EJ22T
Posted: Tue May 25, 2010 2:11 am
by beatersubi
Thats a really neat calculator. I wonder how accurate it is.
Posted: Tue May 25, 2010 2:44 am
by obd1-kenobe
what do you mean accurate? its a mathmagician..u dont do any work and it tells you every spec....perfection
Posted: Tue May 25, 2010 6:29 am
by 93forestpearl
It's only accurate if the data you provide is accurate. Garbage in = garbage out. There is no way to what your VE is at what particular RPM, and who here knows what their BSFC is...
I prefer the hand calculations on Garrett's website.
Posted: Wed May 26, 2010 3:33 am
by obd1-kenobe
No true 93 forestpearl....its on there..hit the refresh tab as I stated in my first post and it all comes up.....
Posted: Wed May 26, 2010 3:55 am
by 93forestpearl
What's not true? Please quote parts you want to refute.
Posted: Wed May 26, 2010 2:11 pm
by obd1-kenobe
hit refresh on the map and all the figures come up....
Posted: Wed May 26, 2010 4:32 pm
by Alphius
He's trying to say you have no way of knowing what BSFC our cars generally run and there is no way of knowing the VE of the engine at a particular RPM. In fact the VE and BSFC numbers in the table look like they are not even close to accurate as-is.
If you put different numbers in for VE at RPM or different numbers for the BSFC it will drastically influence the resulting compressor map, and since there is no way to know the true numbers then this calculator is really only useful as an academic tool. It is pretty cool, but the results you get out of it will almost certainly not match real world results.
You will get much more accurate results by plotting the known airflow of our engines on a compressor map by hand.
Posted: Wed May 26, 2010 6:00 pm
by 93forestpearl
Posted: Thu May 27, 2010 6:14 pm
That's a nice page Dan.
Posted: Thu May 27, 2010 7:59 pm
by impreza_GC8
I played with this calculator for a while but never was able to get it to work for me. I don't know the exact numbers that it needs to be accurate.
To the OP, if you're looking for a bigger turbo, I've got a VF8, injectors and intercooler in the FS section right now. Its no Holset but its larger than TD04 or VF10/11 and works with the stock fuel system.
Posted: Fri May 28, 2010 3:43 pm
by obd1-kenobe
thanks for all the responses and info. You guys rock. and yes dan thats a cool site....
