Custom short throw shifter
Posted: Wed May 26, 2010 4:19 am
So I was having a discussion with Jake ( where it seems I was driving him nuts) but I was trying to explain that I could not find a short throw shifter for our cars online.
( as we have the large ball in the bottom, but the thin section with the bushings)
So we discussed modifying one of the kartboy ones to fit.
Dave steps in and says it should not be a major issue to do some cutting to make it work.
So, we made it work.
So my throws are about an inch.
It is very notchy, but I need to do some final work to make it a bit more smooth.
( A bit more sanding off of material and some lube)
PArt two:
You start with one of these:
Uploaded with ImageShack.us
and you grind down and cut the center section so it turns into this:
PArt two:
