Im currently running a version 4 sti tranny in my 92 ss with a wrx pp and disc. i tried to use a usdm wrx 2 piece flywheel in my clutch tranny sway but it was too thick. I ended up using the jdm one the tranny came with but its heavy ass steel. Does anyone know what app i can get a lightweight flywheel for that'll work with my 22t and sti tranny? Any help would be great.
Thanks,
Grant
Right flywheel for my 92 ss running a version 4 sti tranny
92 SS
-TD04
-3" dp/ turbo back w/HKS can
-wrx/legacy susp combo
-Tribeca Front Sway
-whiteline rear sway
-wrx front brakes
-sti lip
-ver.4 sti tranny w/rear diff
-wrx tmic
-mbc @14.5-15psi w/HKS FCD
-Apexi turbo timer
-TD04
-Tribeca Front Sway
-wrx front brakes
-sti lip
-wrx tmic
-Apexi turbo timer
Re: Right flywheel for my 92 ss running a version 4 sti tran
'02-'05 USDM WRX is the correct spec for a flywheel.
NOT '06+ WRX. Not '05+ Legacy GT.
