SOLD! Legacy SS power antenna 2 for 1 special SOLD!
Posted: Fri Jun 04, 2010 10:33 pm
Sold to Kleinkid.
First power antenna assembly is out of my 1991 SS with 160,000 miles on it. The motor works fine, but the mast is broken. The second power antenna assembly is out of a 1992 SS with 77,000 miles on it. The mast is in perfect condition, but the motor struggles to put the mast up, and I can hear the nylon gears slipping in the case. I took the cover off the case, and the gears appear to be fine. The motor still works.
If you have the time, you could salvage the good pieces from both assemblies, and make one good power antenna. I'm asking for $35 shipped anywhere in the continental US. I'm in Portland, OR. PM me with any questions.
