inexpensive modified-stock foglights for 1st gens
Posted: Sat Jun 12, 2010 10:18 pm
by N1446
Price List includes,
Halogen L-shape foglight Bulbs for late model vehicles 17$ a piece
11x14 sheet of clear lexan from Home Depot 15$
100ft spool of 16 guage electrical wire 15$
foglight switch from 98 legacy gt
the tools i used include an angle grinder for shaping the lexan to match the original mounts and a drill for the holes to match the original mount holes and some sealant to keep the moisture on the outside
result, two high-power crystal clear fogs on the original mounts
I say they turned out pretty good and the wiring is basic
with any luck they wont catch on fire ! HaaHaaH !
Re: inexpensive modified-stock foglights for 1st gens
Posted: Sun Jun 13, 2010 1:57 pm
by SILINC3R
looks good, do you have anymore pics of the install however. for sure want to do this
Posted: Sun Jun 13, 2010 2:21 pm
by kimokalihi
How come you're using blocks under the tires? Do you not have brakes and/or transmission to hold your car in place?
Fog lights look good. Did you still retain blinker function in the same housing?
Posted: Sun Jun 13, 2010 11:46 pm
by jefferson
So you just put a different bulb in the stock housing?
Posted: Tue Jun 15, 2010 3:02 am
by N1446
heay yeah for the most part i put a different bulb in the stock housing, i used a dremmel tool to carve a hole large enough to insert the bulb and then "snap" it in place, and turn the bulb so it stays secure
I still have the original lenses for the lights tho they are as faded and yellow as are the headlights so i made new lenses for them from a sheet of lexan
the blinker lights are relocated to the cornerlights and the car is on blocks because i have a new clutch to install and right now the ebrake needs replacing
this weeks has seen heavy rains too so as soon as it clears up i will lay out the install process, it is really quite simple, from start to finish is only like 2 hrs tops including the wiring
Posted: Tue Jun 15, 2010 3:37 am
by SILINC3R
i made my corner lights into turn signals as well but kept the bottoms also cause i was afraid the corners would not be good enough by themselves
Posted: Tue Jun 15, 2010 7:38 am
by Mikerthebiker
for some reason id be concerned about the heat that would give off having them on for so long especially considering there is no interminent break?
Posted: Tue Jun 15, 2010 4:51 pm
by Redlined
sexy sexy sexy! Love the mod. If only I had a preface I'd do that myself! Wish there was a mod for Post facelift cars that was that easy! Ah well. Ill keep my eyes open for a set of JDM fogs.
Oh... yeah.... cleatcoat your headlights. its quick, cheap, makes your car look better and seriously Improves night visibility.
