93 leg wagon rear lateral links
Posted: Thu Jun 17, 2010 10:11 am
by Danny-G
will these work for adding a rear sway bar to my 93 sedan, would i have to mod anything
Re: 93 leg wagon rear lateral links
Posted: Thu Jun 17, 2010 11:47 am
by TonyAWD
Well, as long as they don't come from an L wagon then you should be good (I'm 90% sure the wagon and sedan share the same links, but look into it anway). I put 98-01 2.5RS rear lateral links on to add a sway bar, and they work pretty good!
Posted: Fri Jun 18, 2010 6:38 pm
They'll work.
Tony's comment about the L wagon I believe was made for the FWD cars. The rear links on the FWD cars are different than the AWD cars. So just make sure the rear links you get the car from are AWD.
Posted: Fri Jun 18, 2010 7:18 pm
by evolutionmovement
I believe from holding an AWD sedan's up to my wagon's, that the FWD are identical to the AWD—the difference is the mounting bolt goes across the subframe. And even the fwd L wagon has a rear antiroll bar.
Posted: Sun Jun 20, 2010 8:00 pm
Pretty sure the bolts and mounting is different between the FWD & AWD. It's been a while since I did my swap, so I could be wrong....
