Show me your gauges
Posted: Fri Jun 25, 2010 9:25 am
by HappyFrog
Sometime soon I'll be needing to fit at least 3 gauges (boost, oil temp, oil pressure) and maybe a 4. (AFR). I'm not a big fan of a-pillar gauges, so I was wondering what everyone else has done?
Re: Show me your gauges
Posted: Fri Jun 25, 2010 12:09 pm
by evolutionmovement
I'm trying to get a hold of scrap blue interior pieces so I can make welding rod and sheet plastic that matches the rest of the car and then I'm going to make Roman vault-shaped enclosure(s) and weld them on the top of the steering column trim. The top of the column would look a little like Mickey Mouse or the letter "B" lying on its back if you removed it, but hopefully also like some kind of unusual factory installation.
Posted: Fri Jun 25, 2010 10:31 pm
by NICO
this is my basic set up, simple works
Posted: Sat Jun 26, 2010 4:25 am
by kimokalihi
I'm going to need to decide where to put mine too. I'm thinking maybe fiberglass them into the gauge cluster bezel. Just need to find a location that won't protrude too much and find a couple areas where it won't block the warning lights or gauges.
Posted: Sat Jun 26, 2010 5:49 am
by SILINC3R
this is one ill have to find the updated pic of it.
