Finaly got off my @$$=put in the EDM lights FRONT AND REARS
Posted: Wed Jul 28, 2010 8:56 pm
by dscoobydoo
The harness had been in the car for months and the lights were just sitting in the box.
So I decided to quit being lazy and put them in.
The passenger one moves just like it should, but the driver side one is a bit wonky. I may have to take it apart again and reset everything.
Re: Finaly got off my @$$ and put in the EDM lights w levele
Posted: Wed Jul 28, 2010 11:00 pm
by kimokalihi
Is there any wiring involved or is the factory wiring all there already? I want some....
Posted: Wed Jul 28, 2010 11:58 pm
by dscoobydoo
You have to create a harness for the levelers to work.
6 wires from the pass light to the drivers light to the dash.
Need to splice into illumination/illumination ground/ power/ power ground
Also the plugs are from an 04 STI light leveler- they did not come with the lights.
Posted: Mon Aug 02, 2010 7:02 pm
FYI, here's the wiring diagram for the EDM lights w levers. I had make one when I got mine since I didn't have the factory manual.
http://www.main.experiencetherave.com/s ... agrams.pdf
Posted: Tue Aug 03, 2010 1:41 am
by dscoobydoo
PART 2: Now have the rear lights with center fog lights ( aka Audi)
Lights on Image
Brakes on Image
Brakes and lights Image
Rear fogs on Image
Re: Finaly got off my @$$=put in the EDM lights FRONT AND RE
Posted: Tue Aug 03, 2010 4:57 am
by reddragons
that's cool. looks good really good. what do the front light levelers do?
Posted: Tue Aug 03, 2010 6:08 am
by kleinkid
You should get back off your ass again, and come up here and install my leveler switch!
Posted: Tue Aug 03, 2010 3:22 pm
by sqc151
we need to add a drooling smiley so i dont have to lick the screen... :smt016 love the rear lights... 8)
me want a set for my 91 SS.
Posted: Tue Aug 03, 2010 3:26 pm
by kimokalihi
Yeah the 90-91 tail lights look like ass. I'm trying to come up with a cool solution for them. Only thing I've come up with is removing the chrome trim and playing around with some tint.
Posted: Tue Aug 03, 2010 6:12 pm
What are the 92-94 rear tail lights supposed to look like?
I'd be cautious of running the "rear fogs" like that as they could be mistaken as brake lights. The german cars like Audi that have a rear fog, only have it on one side, typically the driver's side I believe.
Posted: Tue Aug 03, 2010 6:17 pm
by sqc151
new german cars now have them on both sides.
Posted: Tue Aug 03, 2010 6:20 pm
Really.....crazy Germans.
Posted: Tue Aug 03, 2010 7:06 pm
Wow, those look great! I'm jealous. Didja get some good high-output bulbs and make a heavy-duty wiring harness for them? If not, you'll be re-amazed all over again when you do.
European specs allow for rear fog lights either on both sides or just on the driver's side.
The idea behind having two of them is that then you can kind of gauge how far away a car is. The idea behind having one is, like Josh says, to make them look different from brake lights.
If you're in thick enough fog that you have rear fog lights on, I don't think distance information is that useful since you have to be really close to a car to see the light anyway. If it were my car, I'd leave the passenger-side rear fog light bulb out.
Posted: Wed Aug 04, 2010 1:13 am
by dscoobydoo
The front levelers move the headlights up/down about 3 degrees each mark.
John- it's not that hard- as long as you have a harness= do you?
The bulbs are the factory ones- not super bright.
I thought about running just one side- but I can now use the light for when people tailgate.
Posted: Wed Aug 04, 2010 3:47 am
by kleinkid
What did the harness you used come off of? No, I don't have one.
Posted: Fri Aug 06, 2010 3:48 am
by dscoobydoo
The harness I have is using a few leveler plugs from 04-05 STI's and a wire loom perfect for the harness: 6 small 18 ga wires inside a heat/oil proof wrap. I have asked my electrician if he would be willing to make a few. He said- maybe. but he would need the STI plug ends, the switch and the cost would be between $80-95. But the result is very neat and tidy and easy to put into the car.
Posted: Fri Aug 06, 2010 8:42 pm
by kleinkid
The leveler plugs from the '04-'05 STi plug into the leveler at the back of the STi headlight? Need The harness side at the headlight I presume.
This would plug into the leveler connector on the EDM headlights?
And, give the electrician the EDM leveler switch I have.
All sounds good to me. I'll start looking for the STi parts.
Posted: Mon Aug 09, 2010 3:03 am
by Mattheww044
Kimo, i agree on the ass ends of the 91, I painted almost everything black on mine, and i think it makes it look ALOT better....should look even better when I do the black handles and chrome removal.... I think that double sided tape will come off after a few car washes :D
Posted: Tue Aug 10, 2010 4:34 am
by dscoobydoo
This is what my harness looks like out of the car. You can see the front plugs from the STI, and the switch ( mine did not have plug ends) Image
Posted: Thu Aug 12, 2010 4:00 am
fancy!
