Crank pulley wobble
Posted: Thu Jul 29, 2010 1:14 am
by Impact240sx
Ok so i just bought a Legacy off my parents, my dad had it tore down as soon as he noticed the wobble, its not too horrible but its still wore it out a little bit. My crank snout looks very similar to this one
Now my question is, what do you guys recommend to fix it? I was thinking of getting a new keyway, and just tack welding it in and trying to file it down so the pulley will fit back on there. Any suggestions?
Re: Crank pulley wobble
Posted: Thu Jul 29, 2010 2:30 am
by evolutionmovement
Does a key fit in it? I would throw a new key in and tighten that one in the picture up to 110-120 lbs. and call it a day. As long is it holds it tight, it should be fine. Happened worse to mine and I drove it over 100k miles further without issue.
Posted: Thu Jul 29, 2010 3:38 am
by Impact240sx
Not sure, gotta get a new key and stuff from the dealer tom.
Posted: Thu Jul 29, 2010 11:13 pm
I'd second what Steve said to do. If your keyway looks like the picture you should be fine.
Posted: Fri Jul 30, 2010 3:04 am
by Impact240sx
Probably gonna be what i do. Does anyone have a radiator that would work with my car? Needing one of those as well.
Posted: Fri Jul 30, 2010 4:12 am
by 93forestpearl
Where are you located?
Posted: Sat Jul 31, 2010 3:06 am
by Impact240sx
Southern Ohio 45680
