2wd trans problem
Posted: Wed Aug 18, 2010 11:20 pm
by justin the subie
so aperently i messed up the trans pump when i installed a new motor... the engine runs great but the trans will no longer go in gear..
options i have at the moment are,
Swapping over to 4wd Auto,
or a Turbo 4wd Auto,
or taking the trans apart and fixing the pump..
any advise for the best fix is greatly aprecated :smt033
Re: 2wd trans problem
Posted: Thu Aug 19, 2010 6:23 pm
Well, the AWD transmissions are not going to work on a FWD car. So depending on what broke, you may be better fixing your trans, or trying to find another one.
Posted: Thu Aug 19, 2010 6:34 pm
by justin the subie
not going to work what so ever? what are the details? ive got a rearend and axles wiring harness... maybe there is something im missing?
Posted: Thu Aug 19, 2010 6:39 pm
Wait....are you looking to do an AWD conversion? If so, then yes you can use the AWD transmission. You didn't elaborate you were planning on doing an AWD swap.
Posted: Thu Aug 19, 2010 7:07 pm
by justin the subie
oh i see.. lol ive got everything to do the swap.. just dont know if the plugs on the trans wires are the same.. ive done a auto to manual swap before but not a 2wd Auto to 4wd Auto swap... hoping to find out all the details before i get too excited..
my best trans i have is the turbo Auto.. would that work or would i have to do a whole wire harness?
thanks for the help guys! :smt033
Posted: Fri Aug 20, 2010 5:49 pm
There should be no difference in electrical connector plugs between the FWD & AWD AT transmissions.
