so the ej22e has better flowing head intake then the ej22tDrinkItDown wrote:.:Originally Posted on 10/12/09 on Columbus Racing:.
MR2 is going bye bye, and I am picking up an EJ22T shortblock on Saturday from someone on RS25.com . Don't plan on doing anything super special with it, just something to have fun with rallycrossing and playing in the snow. The motor that is in it has a bunch of issues, and I am pretty sure the block is cracked. Probably won't see an autocross, as the transmission is too fragile for it. If it did, I would be babying it for sure.
Anyway, short parts list:
EJ22T bottom end
EJ22E Heads/Cam/Intake
Not sure what to do about an Intercooler, I hear there are clearance issues with a WRX one, maybe a stock EJ22 one.
WRX Injectors
WRX exhaust bits
WRX crossmember
TD04 Turbo, maybe a VF39, but I kind of want to avoid lag as much as possible.
Megasquirt II
Walboro 255 lph
and I'm changing out the tranny for a new one.
DrinkItDown's 1996 Subaru Impreza GM6 EJ22T/EJ25 hybrid
Re: DrinkItDown's 1996 Subaru Impreza GM6 EJ22T/EJ25 hybrid
You can use a 02-05 WRX intercooler but you'll most likely need to take a hammer to the firewall to get it to fit. 06-07 fits just fine. There is no stock EJ22 intercooler. Only EJ20G/K/H/R I believe and of course the newer WRX and STI ones.
huh???????? I DIDNT WRITE THAT ^^^ IS it just me are does it show that post from me^^^^UP
You had disable bbcode enabled, so it didn't do the quotes. I renabled it.
