Torquing the crank pulley bolt
Posted: Fri Sep 24, 2010 8:38 pm
by Impact240sx
Dumb question but i just did my timing belt/water pump. How can i keep the motor from turning when Im trying to torque the pully down? 2.2 Ej22. Motor is still in the car.
Re: Torquing the crank pulley bolt
Posted: Fri Sep 24, 2010 9:28 pm
by 07Evolved
Posted: Fri Sep 24, 2010 9:36 pm
by Impact240sx
What did you do? Just wrap that around the big crank pulley ??
Posted: Sat Sep 25, 2010 4:50 pm
by cj91legss
i usually just put it in gear w/ e-brake engaged
Posted: Mon Sep 27, 2010 7:37 am
by 91legacyawdturbo
There should be a small hole in the back side of the bell housing on the engine side. take the starter off and you should be able to find it, its half way down the back side of the motor, 1/4 of an inch big Take a punch and put it in there it'll lock the flywheel in place so you can safely torque the crank bolt.
Posted: Mon Sep 27, 2010 1:09 pm
by 07Evolved
Impact240sx wrote:What did you do? Just wrap that around the big crank pulley ??
yes. either hold it yourself to keep the crankshaft pulley in place or get a buddy to hold it while you torque the bolt to spec. I had no problems and it worked well.
