FS: Fuel Cut Defender - FCD
Posted: Fri Oct 01, 2010 4:54 pm
Had this on my Legacy swap. Worked great.
I'm including an unused AA battery box to mount it.
The harness has one spot where the outer covering was torn and has been taped over. The wires tested good end to end.
Instructions included and avl. HERE, which is where I bought it.
PLEASE DO YOUR RESEARCH on this as YOU WILL BLOW UP YOUR ENGINE IF YOU DON'T KNOW WHAT YOU'RE DOING!!!!!!
$30 Shipped.
$30 Shipped.
