4 JDM 480 CC injectors, refurbished and tested....
Posted: Sat Oct 30, 2010 4:24 pm
1st 120 bucks takes them. I used them and found I'd rather go back to stock rather than continuing down the path of more speed. It's a long story but that is the meat and potatoes of it as it relates to the potential buyer. Having already been in the car and working well the injectors will not need anything to install, the tops have already been turned to slide right in. The only thing you'll need is the bottom o-ring off your existing injectors and thanks to the rest having been done it should take no more than 45 mintues to install these. If you already got the revtronix chip you are more than halfway to an 100 HP increase.
