Bushings
Posted: Mon Nov 29, 2010 8:39 pm
by SubyFusion
where is a good place to find Transmission Cross Member Bushings, and Differential Bushings online for a good price I can't seem to find any!
Re: Bushings
Posted: Mon Nov 29, 2010 10:31 pm
by subaru_styles
turn in concepts
Re: Bushings
Posted: Tue Nov 30, 2010 1:56 am
by SubyFusion
Thanks subaru styles :D
Re: Bushings
Posted: Mon Jan 03, 2011 11:01 pm
by SubyFusion
Is there a place that I can get some Stiffer bushings for the diff?
Re: Bushings
Posted: Tue Jan 04, 2011 6:57 pm
I think you can probably get some from TiC, kartboy, whiteline, or superpro.
Not all of them may have one, but one of them probably has it. Our diffs use a bracket and the bracket has metal collared bushings. They are a pain to remove! If you can find replacement bushings, hopefully they are just poly bushings you can install by hand.
If all you can find is the hardened rubber STi/group N bushings, I wouldn't bother. That's kind of why I didn't replace my rear diff bushing a couple years back. All I could readily get was the STi bushings, and they are a living pain in the arse to replace.
Re: Bushings
Posted: Tue Jan 04, 2011 7:03 pm
by SubyFusion
I bought some Kartboy outrigger Bushings thinking they would fit when I did my swap, but the top Bushings didn't work so I still haven't put them on. I bought them from TIC
Re: Bushings
Posted: Tue Jan 04, 2011 7:11 pm
The kartboy outrigger bushings should work. I've got them on my Legacy. They are kind of confusing on how to install though.
Re: Bushings
Posted: Thu Jan 06, 2011 5:22 am
by SubyFusion
The smaller ones work but I cant figure out the larger ones!
Re: Bushings
Posted: Thu Jan 06, 2011 6:59 pm
They just go between the body and outrigger.....they just kind of sit there.
This is assuming they're anything like the whiteline outrigger bushings.
Any chance you could snap some pics?
